Calefacción domotizada con válvulas y termostaro
Hola a todos!
Tengo un termostato Netatmo integrado perfectamente en HA y estoy pensando en coger válvulas para los radiadores de este estilo:
El tema es que quien enciende o apaga la caldera es el termostato del salón por lo que no sé cómo podría hacer para que, si hay alguna válvula en cualquier estancia cuya temperatura es inferior a la estipulada, esta "hable" con el termostato para encender la caldera, independientemente de la temperatura del salón. Lo suyo sería formar un "grupo" con las válvulas y que, si algun componente de ese grupo cumple el requisito de temperatura inferior, se encienda la caldera y, de lo contrario, se apague.
Pero no tengo ni idea de cómo hacerlo
Gracias por adelantado!!
Re: Calefacción domotizada con válvulas y termostaro
I have been reading out a few of your stories and it’s pretty nice stuff. I will make sure to bookmark your site 우리카지노
I really treasure your work , Great post. Esta meille viisumikelpoisuus Puolan kansalaiset
i think that RSS FEEDS should also be included on the list of the best inventions because it makes life easier for bloggers like us. pentobarbital for sale
Oh my goodness! an incredible article dude. Thanks Nonetheless I am experiencing concern with ur rss . Don’t know why Unable to subscribe to it. Is there anybody getting equivalent rss drawback? Anyone who knows kindly respond. Thnkx Caluanie Muelear Oxidize For Sale
Wow, incredible weblog format! How long have you been running a blog for? you make running a blog look easy. The whole look of your web site is magnificent, well the content material! đăng ký 8DAY
you are actually a just right webmaster. The site loading pace is incredible. It kind of feels that you are doing any distinctive trick. In addition, The contents are masterpiece. you’ve done a great process on this topic! 바카라사이트
Hello There. I found your blog using msn. This is an extremely well written article. I will be sure to bookmark it and return to read more of your useful information. Thanks for the post. I’ll certainly comeback. Learn SEO online class
After i bought against your site however adding desire only marginally touch submits. Exciting way of permanent, Soon we will be book-marking each time get hold of styles entire can come in place. คาสิโนufabet
The moment when i been given onto your web page while having factor in essence considerably touch submits. Gratifying strategy for impending, My business is bookmarking while doing so attain forms conclude springs up way up. เกมคนติดหม้อ
