ERROR CONTROLES SERVIDOR NI REINICIA NI VERIFICA
Hola.. llevo una semana que no me es posible verificar ningun cambio y tampoco me deja reiniciar el sistema.
he apagado la pi por si acaso solucionaba algo pero nada de nada.
este es el error que me da.
por favor a ver si alguien supiera como solucionarlo.
Logger: homeassistant.core
Source: helpers/config_validation.py:755
First occurred: 3:03:28 (2 occurrences)
Last logged: 10:34:16
Error executing service: <ServiceCall homeassistant.restart (c:0763ae6afec8586eab0090bfb19083f5)>
Error executing service: <ServiceCall homeassistant.restart (c:a7a095896479e0101d5e0511b8a95d27)>
Traceback (most recent call last):
File "/usr/src/homeassistant/homeassistant/core.py", line 1464, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1483, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 378, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 874, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 177, in async_check_ha_config_file
p_validated = platform_schema(p_validated)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 470, in verify
return cast(Dict, schema(value))
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 338, in _exec
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 755, in validator
if key in config:
TypeError: argument of type 'NoneType' is not iterable
await coro_or_task
return schema(data)
v = func(path, v)
return schema(data)
if key in config:
Re: ERROR CONTROLES SERVIDOR NI REINICIA NI VERIFICA
solucionado... cierro tema
Hola Javier me puedes comentar como lo solucionaste? Me pasa lo mismo, Gracias
We extremely appreciate your website post. There are dozens of techniques we could put it to proper use with a minimum of effort with time and capital. Thank you so much for helping make the post give light to many queries we have got before now. فتح شركة في الامارات
Just want to say your article is as amazing. The clarity in your post is just nice and i can assume you are an expert on this subject. Fine with your permission allow me to grab your RSS feed to keep up to date with forthcoming post. Thanks a million and please continue the rewarding work. Chamberlain Overhead Garage Door Repair Encino
I recognize there exists a great deal of spam on this blog site. Do you need help cleaning them up? I can help among courses! আমেরিকা ভিসা অনলাইন
There is noticeably a lot of money to learn about this. I suppose you have made certain nice points in functions also. oxbetwin
This website is usually a walk-through for all of the details it suited you concerning this and didn’t know who to question. Glimpse here, and you’ll definitely discover it. Local Gate Operator Repair Services Vista
e bingo online
I found this post very interesting and informative. Thank you for sharing your special thoughts with us. My site:
online bingo cards
online bingo cards
Oh my goodness! a fantastic write-up dude. Thanks a lot However We’re experiencing issue with ur rss . Do not know why Struggling to register for it. Could there be any person getting identical rss dilemma? Anyone who knows kindly respond. Thnkx where to buy pentobarbital
