- instalar en Node-RED node-red-contrib-home-assistant-websocket y node-red-contrib-telegrambot ( NODE-RED, manage palette, install)
- importar el flujo en Node-RED (copiar codigo, Node-RED, import clipboard, pegar):
Código: Seleccionar todo
[{"id":"9ce68a37.b5c18","type":"server-state-changed","z":"e7cd7cb.c8e3f8","name":"cambio estado rele","server":"","entityidfilter":"switch.","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"x":130,"y":60,"wires":[["57f8d820.0d8928"]]},{"id":"57f8d820.0d8928","type":"change","z":"e7cd7cb.c8e3f8","name":"traductor estado","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"encendida","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"apagada","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"unavailable","fromt":"str","to":"sin conexión","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":100,"wires":[["aaed62b1.f141f"]]},{"id":"aaed62b1.f141f","type":"function","z":"e7cd7cb.c8e3f8","name":"componer mensaje","func":"msg.payload = {chatId :XXXXXXXXXX, \n type : 'message',\n content : msg.data.new_state.attributes.friendly_name + \" \" +\n msg.payload }\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":100,"wires":[["f074a44c.13065"]]},{"id":"80b704fa.ddbf2","type":"server-state-changed","z":"e7cd7cb.c8e3f8","name":"cambio estado luz","server":"","entityidfilter":"light.","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"x":130,"y":140,"wires":[["57f8d820.0d8928"]]},{"id":"f074a44c.13065","type":"telegram sender","z":"e7cd7cb.c8e3f8","name":"telegrambot","bot":"","x":770,"y":100,"wires":[[]]}]
Se necesitan tres valores:
1- access token de home assistant.
En home assistant, botón configurar usuario (arriba la izquierda, inicial del usuario), Tokens de acceso de larga duración. Crear uno y copiarlo.
2- Token del boot de telegram. Se obtiene al crear el boot de telegram
3- Telegram id. yo lo obtuve preguntando al boot IoTwithus.com escribiendo /myid
Doble click en el nodo "cambio estado rele", boton editar server, poner la url (http://localhost:8123) y el access token (1)
poner también el mismo server en "cambio estado luz"
doble click en el nodo "telegrambot", y configurar el acceso al boot (boot-name, token (2), y chatid (3)
doble click en el nodo "componer mensaje" y poner en chatId :XXXXXXXXXX el de nuestro chat (3)
Si todo va bien, en cada cambio de estado de cualquier luz o rele, lo notifica. por ejemplo: "luz salon encendida" o "luz salon apagada".
