No funciona silicon labs multiprotocol
iac304es
Mensaje por iac304es » Lun May 15, 2023 9:36 am
No me carga el complemento de silicon labs multiprotocol
Me da esto el log
curl: error while loading shared libraries: /usr/lib/aarch64-linux-gnu/libnettle.so.8: invalid ELF header
[09:02:47] ERROR: Something went wrong contacting the API
[09:02:47] INFO: The otbr-web is disabled.
s6-rc: info: service mdns: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/check-cpcd-shm.sh
[09:02:48] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (May 8 2023 09:33:46) starting
Default: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0)
cont-init: info: /etc/cont-init.d/check-cpcd-shm.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
[09:02:48] ERROR: Something went wrong contacting the API
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[09:02:48] INFO: The selected serial port is not a USB device.
[09:02:49] WARNING: No firmware found for the selected device, assuming firmware is installed.
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service cpcd-config: starting
[09:02:49] FATAL: No serial port device set!
s6-rc: warning: unable to start service cpcd-config: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service mdns: stopping
s6-rc: info: service universal-silabs-flasher: stopping
Default: mDNSResponder (Engineering Build) (May 8 2023 09:33:46) stopping
s6-rc: info: service universal-silabs-flasher successfully stopped
s6-rc: info: service banner: stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[09:02:49] INFO: mDNS ended with exit code 4 (signal 0)...
s6-rc: info: service mdns successfully stopped
