hassio no arranca tras corte de luz
Hassio en raspberry 4. Cuando tengo corte de luz, una vez restablecido el suministro hassio arranca.
Tengo que desconectar la raspberry y volverla a conectar para que todo funcione correctamente.
Supongo que será porque la rapberry arranca antes que el router. ¿Existe alguna forma de retrasar el arranque de hassio hasta que la red local este totalmente operativa?. Tengo la raspberry en ip fija.
Gracias.
Gracias.
Re: hassio no arranca tras corte de luz
Es raro... pero le podrías poner un SAI al router o ponerle un IP FIJA a hassio sino la tienes. (La gente tiene mania de ponerla por dhcp).
Gracias por tu sugerencia. Tendré que pensar en poner un sai ya que tengo la ip fija en hassio y no se como decirle a hassio que no arranque si no esta completamente restablecida la red.
Excellent read, I just passed this onto a colleague who was doing a little research on that. And he just bought me lunch because I found it for him smile Thus let me rephrase that: Thank you for lunch! 우리카지노
I was just seeking this info for a while. After six hours of continuous Googleing, finally I got it in your site. I wonder what’s Google’s issue is! Thank you for the help! تاسيس شركة في دبي
I am not rattling great with English but I get hold this really easygoing to read . Pa mor hir ar gyfer Cymeradwyaeth Visa Americanaidd
I surely didn’t know that. Learnt one thing new these days! Thanks for that. Viking Gate Repair Los Filez
I wasn’t sure where to ask this, i wondered if the author could reply. Your blog looks brilliant and I wondered what theme and program you used? Any help would be a big help and i would be very greatful as I am in the process of beginning a blog similar to this subject! oxbetwin
The Star Trek score is great also, Kirk’s theme is cool, the title theme is beautiful, although I missed the fanfare. Köp lagligt cannabis
You need to be a part of a tournament for example of the greatest blogs over the internet. Let me suggest this blog! byta bolån
