Apagar o encender el PC con home assistant o alexa
¿Has conseguido solucionar algún problema en Home Assistant y quieres compartirlo? ¿Alguna automatización para ayudar al resto? ¡Comparte!
pedro
Mensaje por pedro » Jue Dic 27, 2018 7:01 pm
Con home assistant:
Código: Seleccionar todo
switch:
- name: reniciar
    platform: command_line
    switches:
     apagar_pc:
      command_off: "net rpc shutdown  -I ip.del.pc.en.la.red.local -U usuarioPC%suclave"
      command_on: "wakeonlan direccion.mac.de.la.tarjeta.de.red.del.PC"
      command_state: "ping -c2 ip.del.pc.en.la.red.local"
      friendly_name: "PC casa"
con node-red y alexa:
Imagen
[{"id":"9d47b2cc.b879c8","type":"alexa-home","z":"be2411d8.7086b","conf":"3487ef6.9c68e9","device":"49088","acknoledge":true,"name":"ordenador","topic":"","x":80,"y":540,"wires":[["ad13826d.95faf8"]]},{"id":"ad13826d.95faf8","type":"switch","z":"be2411d8.7086b","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":250,"y":540,"wires":[["85641df5.189118"],["d3525dbd.a9aec8"]]},{"id":"85641df5.189118","type":"exec","z":"be2411d8.7086b","command":"wakeonlan mac.de.la.tarjeta.de.red","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":560,"y":540,"wires":[[],[],[]]},{"id":"d3525dbd.a9aec8","type":"exec","z":"be2411d8.7086b","command":"net rpc shutdown  -I ip.del.pc.en.red.local -U usuarioPC%suClave","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":660,"y":600,"wires":[[],[],[]]},{"id":"3487ef6.9c68e9","type":"alexa-home-conf","z":"","username":"usuarioSkill"}]
En la raspberry:
sudo apt-get install samba-common
sudo apt-get install wakeonlan
En el PC activar shutdown remoto y el wake on lan:
https://www.online-tech-tips.com/comput ... n-command/
https://www.howtogeek.com/109655/how-to ... ndows-pcs/
https://www.redeszone.net/2018/02/10/ac ... indows-10/
Última edición por pedro el Sab Feb 02, 2019 2:05 pm, editado 11 veces en total.
goliath
Re: Apagar o encender el PC con home assistant
Mensaje por goliath » Vie Dic 28, 2018 7:03 am
Bua, genial, la verdad es que siempre se aprenden cosas en esto.
Yo lo estaba haciendo, pero por desconocimiento, de una manera mucho más complicada:
- Por un lado, haciendo ping a los equipos para saber si estaban on/off.
- Por otro lado, el wake_on_lan.
- Y en cuanto a apagar el pc, tengo que mirar bien de como activarlo, ya que ni me lo había planteado.
Pero así queda todo mucho más limpio y en una sola vista, gracias!
eduardo
Site Admin
Mensaje por eduardo » Dom Dic 30, 2018 6:55 pm
Ostras! no había caído! el WoL me viene genial, ¿te importa si lo publico en la web?
pedro
Mensaje por pedro » Lun Dic 31, 2018 3:04 pm
no me importa.
Faltaría poner todo lo que hay que hacer en windows tanto para activar el shutdown remoto, como el
wake on lan. Hay manuales en la red sobre eso. El wake on lan solo funciona con tarjetas de red, con
un PC conectado por wifi no va, el wireless no tiene esa característica creo.
eduardo
Site Admin
Mensaje por eduardo » Lun Dic 31, 2018 3:20 pm
Ya ya, al igual que en linux habrá que hacerlo por SSH, pero la idea es buena y creo que puede gustar, me pongo con ello
amiguelezg
Mensaje por amiguelezg » Mié Ene 02, 2019 7:09 pm
Que bueno ,.. tengo que probarlo.
